Hi Guys.
What suggestions do you have for scissors? I've gone through three pair in attempt to find something that will cut without spitting the cloth back unharmed. There has to be an easier way!
Scissors for cutting fiberglass.
You need these Wiss fiberglass scissors.
Link: Wiss Fiberglass Scissors
I usually use these electric shears, though. They look hokey, but they work excellently. For any job requiring a lot of cutting, these are well worth it. I love them.
Link: EC Cutter
Link: EC Cutter
- Wood Whisperer
forget scissors. Go to the fabric department at Walmart ( or any other fabric shop) and get a fabric cutter. It's a roller device with a razor sharp wheel in it. Lay a straight edge down and run the wheel along it- sharp, straight cuts.
Costs less than 10 bucks.
I've used mine through the building of 3 boats now and am currently using it to cut Fabmat . A layer of roving with a layer of mat attached. Cuts like a breeze and still going strong.
DO NOT get your finger in the way- it doesn't care if it's glass or flesh.
- Wood Whisperer
Yep- about 2 inch diameter, with a cover that retracts as you push down. Rachel- it's really slick, I can cut strips of tape from a piece of cloth as fast as I can lay a straight edge down and roll the thing along.
Put a piece of cardboard under so you don't cut the table you're working on.
just walk into any fabric shop and ask for a fabric cutting wheel.
I used a cutting wheel for the Dynel when I did my decks. It is a slick little gadget, but the underlying surface is absolutely critical to the success of the cut. It's great on a worktable, but up on the boat I prefer scissors. I don't own any that are specifically made for cutting glass, I just buy the $2 variety and discard them when they dull.
The little electric shears look supercool. I've never splurged on a pair because I just KNOW I'd get some resin on them and ruin them, but then last month I noticed some (non-rechargeable) ones in the discount store for like $12 or so. hmmmmmmmmmmm.
Update:
Tried a pair of scary sharp recycled chicken factory scissors recommended by the hardware store down at the coast. Grabbed a pair of three dollar pakistani chromed stamped steel safety scissors with serrations. I'll be darned if they don't fly through glass, the little teeth on the blade keeps the glass from sliding out.
P.S. A filet knife makes fast work of finishing cloth...
Tomorrow I'll go grab a cutting wheel.
