I did some searching and I see that folks here have discussed the "hot glue method" but I couldn't find a specific description of the process.
The other day I tried using some to tack support cleats for the seat on my dingy but wasn't sure how to really go about it. Do you leave a spot clear of epoxy adhesive and put a dot of hot glue there? Apply the hot glue to the hull and press the epoxied piece to it? Run a weld bead along an edge after putting the piece in place?
I'd be interested in learning more.
chuck.
Hot Glue Method
- mobilchuckje
- Boat Name: TOFU
- Boat Type: Islander 21
Re: Hot Glue Method
I'm glad you posed this question, chuck. I've thought that it sounds like a great method, but I too wondered how folks have gone about it, and what tricks or tips they've learned to make it work (better).
Re: Hot Glue Method
I love my hot glue gun--it's absolutely invaluable to me. I've been using one for 20 years, and I am sure I'd figure out how to proceed without one, but to me it sure makes life easier.
Usage varies, but typically I'd omit the "real" adhesive from a couple strategic spots on whatever I was securing and shoot some of the hot glue there to hold the piece while the epoxy cures. I choose the hot glue spots based on where the piece might hit the substrate most closely, to ensure a good bond with the hot glue--it isn't really gap-filling.
I also frequently use the hot glue gun to attach temporary blocking, etc. for help in aligning structures or whatever; the glue is strong enough that it's possible to clamp to the glued-on block as well. A quick knock with a hammer and the glued block releases when I'm done. Obviously I don't do this on finished surfaces.
Hot glue is really hot! Watch it.
- mobilchuckje
- Boat Name: TOFU
Re: Hot Glue Method
Super. Thanks.
Re: Hot Glue Method
I use hot glue to make patterns. Invaluable there as the set up time is seconds. I will use small dots of it to attach the pattern in place while I build it. I also use it for attaching some decorative pieces that don't need a super bond and may even need removal later on. I particularly like it for small decorative wire chases applied to bulkeads.
One Way David
- Boat Type: Pearson Ensign
Re: Hot Glue Method
Another use, cut 1/8-1/4 luan or particle board or scrap ply or cardboardinto 4" strips, Length depends on the radius you are trying to pattern. Frame a moc bulkhead (using hot glue to fix the pieces), counter top, cabinet or whatever. Use a compass to scribe the curve of the hull, or whatever you are fitting.Cut to the line and you have a custom almost perfect fitting bulkhead or counter top or whatever.
Re: Hot Glue Method
I use hot glue in a similar way to David...
Though I rip 2 inch wide stuff of door skins or 1/8th inch ply... then use the fingers to go out and touch the hull. It takes a pretty tight radius for 2 points 2 inches apart not to describe the curve... Then go back and play connect the dots for tight stuff, or warp a batten for big stuff.
