Did you ever procrastinate over a job you weren't 100% comfortable in doing? eg: Installing a thru-hull for the engine cooling system. My concern about: Would I get things in the right place, not only to fit correctly, but also to look as if it "belonged".
I eventually went ahead yesterday and drilled the hole through the bottom of my boat at the turn of the bilge. Being a small boat, I had to work in a confined area. I installed the strainer type thru-hull complete with 3/4" ply backing. Next I reqired what I estimated to be a 45degree elbow plus a 4" nipple and a shut-off valve. These were obtained from a local irrigation supply company. They are red-bronze of marine quality, and half the price of identical product at the local chandlery.
Anyway, all parts were eventually installed and, much to my delight, I had (by pure luck) chosen the perfect location for the "hole" ... the nipple and shut-off are perfectly vertical and nestled away in an area that is just right for the engine and pump hose connection access. Furthermore, the shut-off handle is accessible and easily seen to know if it is open or closed. ... Phewww! what was i so worried about?
Blind luck?
Skipper599
- Boat Name: "MACUSHLA"
Blind luck?
I am: Bob of Wight.
s/v 'Ros Na Cosquin'
a 'Passage - 24'
a 'Passage - 24'
Re: Blind luck?
If drilling a hole in the bottom of a perfectly good boat did not worry you, then there is something wrong with you!!!!!!
I am glad to hear that you time spent contemplating paid off with good results. Don't ever let on that blind luck had anything to do with it ;)
