How do you test an anti-siphon valve?
jetboy52
- Boat Name: Miss Nettie
- Boat Type: Alberg 37
What is the easiest method?
Re: How do you test an anti-siphon valve?
See if you can gently blow through the vent fitting. If air passes, it will break the siphon.
