Triton cabintop thickness
What's the thickness of the core in the triton cabintop? Particularly under the mast step.
This weekend's mission is to lay a solid epoxy and fiber base under the mast step (non-compressive connection between mast step and support beam below), and my plan is to use a router to cut the boundary of this area to a 45 or 30 degree taper. first I gotta buy a router bit of sufficient depth.
Should be 3/8", like the sidedecks.
George ( Triton #236 )
Post by George ( Triton #236 ) »
Mine is 3/8" balsa core.
George
